Rachel's avatar
Rachel
7 years ago
Need to reject traffic based on header names not values
We have a need to reject traffic based on the case of the header names not header values.
For example: Let's say the header name is Trueheader. If a payload comes in with a header name of TRUEheader, it needs to be rejected.
I'm having difficulty capturing the header names to test the case. Is this possible with an iRule?
Thanks in advance for any assistance.
  • Yes, you can do this, via the HTTP::header names command, which returns a list of headers in the request or response, and then iterate through the list using the HTTP::headers count command and lindex.
    I'm not sure about the overall efficiency (you'd have to test), but I would extract the list of header names, and make a lowercase comparison to your check value (e.g. 'trueheader') if and only if that comparison was valid, I would make a second check, comparing the actual case of the header name your your check value. If you match on the lowercase comparison, but not the actual case comparison, you know that you've come across a variant form of your header name and you can reject the configuration.
  • Alternatively you can just use
    HTTP::header exists
    command in your iRule, e.g.
        if {[HTTP::header exists "Trueheader"]} {
             reject or redirect
            reject
  • Hi Rachel,
    to check if a given request contains a badly formated HTTP header name, you may use the iRule below. It first checks if the request does not contain the correctly formated
    Trueheader
    . If a correctly formated
    Trueheader
    is not found, it continues to check if an other-wise formated
    TrUeHeAdEr
    exists in the request. If an other-wise formated
    TrUeHeAdEr
    is found, it will send a HTTP-400 bad request to the client...
        if { ( [lsearch -exact [HTTP::header names] "Trueheader"] == -1 )
         and ( [lsearch -exact [string tolower [HTTP::header names]] "trueheader"]  >= 0 ) } then {
            HTTP::respond 400 content "BAD REQUEST"
            return
    I guess it would be also solution to transparently replace
    TrUeHeAdEr
    with
    Trueheader
    , isn't it? If so then you may check out the iRule below. Instead of sending a HTTP-400 bad request it will store the value of the other-wise formated
    TrUeHeAdEr
    into a
    $trueheader
    variable, remove the
    TrUeHeAdEr
    and finally add a correctly formated
    Trueheader
    with the value stored in the
    $trueheader
    variable.
            set trueheader [HTTP::header value "trueheader"]
            HTTP::header remove "trueheader"
            HTTP::header insert "Trueheader" $trueheader
    Cheers, Kai
