Chris_Paulraj_1
Jan 05, 2009Need some help to understand the violations reported by ASM
Is there any documentation or website that would help to understand the HTTP violations better? When ASM reports "Multiple decoding" or "Modified Domain cookie", I am not able to explain exactly what needs to be fixed to the application developers. Though ASM provides the full request, it would be helpful if it gives out more information about the violation! I appreciate any input.
thanks
Chris Paulraj
- Ido_Breger_3805Historic F5 AccountHi Chris,
Your point is noted. We will provide such explanation within the GUI in the following ASM releases.
In the meantime, Have you looked in the online help for the page that sets the blocking policy (policy->blocking-settings) or the manual?
Cheers,
Ido Breger
Product Manager, Security.
