skkg_111590's avatar
skkg_111590
Nov 11, 2010
need irule help
I need help as I am new to irule
When user tries to go to
1. http://abc.com/secure/* ----------it should redirect to https://abc.com./secure/* --works all fine.
when HTTP_REQUEST { if { [HTTP::uri] contains "secure"} {HTTP::redirect "https://[HTTP::host][HTTP::uri]" }
Now I want to have another condition that when
2. https://abc.com/* ---it should redirect to http://abc.com/*
  • Please feel free to revise.
    virtual bar2-http {
    snat automap
    pool foo2
    destination 172.28.17.120:http
    ip protocol tcp
    rules http-redirect
    profiles {
    http {}
    tcp {}
    virtual bar2-https {
    snat automap
    pool foo2
    destination 172.28.17.120:https
    ip protocol tcp
    rules https-redirect
    profiles {
    clientssl {
    clientside
    http-profile {}
    tcp {}
    pool foo2 {
    members 10.10.70.120:http {}
    profile http http-profile {
    defaults from http
    redirect rewrite matching
    rule http-redirect {
    if {[HTTP::uri] starts_with "/secure/"} {
    HTTP::redirect "]"
    rule https-redirect {
    if {not ([HTTP::uri] starts_with "/secure")} {
    HTTP::redirect "]"
    curl -I http://172.28.17.120/
    HTTP/1.1 200 OK
    Date: Thu, 11 Nov 2010 20:06:56 GMT
    Server: Apache/2.0.59 (rPath)
    Last-Modified: Thu, 11 Nov 2010 04:23:21 GMT
    ETag: "1315d-5f-5580a040"
    Accept-Ranges: bytes
    Content-Length: 95
    Content-Type: text/html; charset=UTF-8
    curl -I http://172.28.17.120/secure/
    HTTP/1.0 302 Found
    Server: BigIP
    Connection: Keep-Alive
    Content-Length: 0
    curl -Ik https://172.28.17.120/
    HTTP/1.0 302 Found
    Server: BigIP
    Content-Length: 0
    curl -Ik https://172.28.17.120/secure/
    HTTP/1.1 404 Not Found
    Date: Thu, 11 Nov 2010 20:07:31 GMT
    Content-Type: text/html; charset=iso-8859-1
  • As a footnote: you can use HTTP classes to accomplish the same functionality. If you see a ton of these conditions coming up soon, it may be best to stick with an iRule. But if not, an HTTP class profile may be the way to go.
    -Matt
  • Thanks alot for the help.
    I want to create one irule which satisfy both the below conditions
    1. http://abc.com/secure/* ----------it should redirect to https://abc.com./secure/* --works all fine. (Thanks for the help guys)
    2. https://abc.com/* ---it should redirect to http://abc.com/*-- ( Still not working)
    Can you please check my irule
    when HTTPS_REQUEST { if {not ([HTTPS::uri] starts_with "/secure")} {
    HTTPS::redirect "http://[HTTP::host][HTTP::uri]"
    Thanks for the help
  • i'm afraid that we don't have HTTPS_REQUESt event and HTTPS::uri as well.
    btw, what virtual server port are u running? is it any port (*)??
  • hoolio's avatar
    hoolio
    You can use the same HTTP events and commands on an HTTPS VS by adding a client SSL profile to decrypt the SSL and parse the HTTP.
    Aaron
