Need help writing irules
I am new to wriitng irules and was needing some help. I need to write an irule that will redirect the following
https://resetmypasswordqa/itim/self
http://resetmypasswordqa
http://resetmypasswordqa/itim/self
to URL https://resetmypasswordqa/itim/self/Login/Logon.do
Any help or ideas is greatly appreciated.
Gary
- What_Lies_Bene1
Perhaps we can simplify things for the port 80 Virtual Server? I assume you don't want to allow any port 80 traffic at all and if so you can just do this;when HTTP_REQUEST { HTTP::redirect " https://resetmypassword.okdhs.int/itim/self/Login/Logon.do" } - nitass
Employee
"/resetmypassword/itim/self/Login/Logon.do" { small L please. - GFort_32452
That is exactly what I needed "What Lies Beneath", thank you very much.
nitass, tried the small L and redirects did not work. Not sure why IBM used upper case instead of lower case.
Thanks for all your great help!
Gary - What_Lies_Bene1
Both L's need to be lowercase, good spot nitass; that was probably the problem, just a little too late =]
You're welcome Gfort
