Need help writing an Irule for a CSS to F5 migrationi
We currently have 2 url's pointed to 1 Virtual IP, if the url contains "thelinkrpts" it will forward to pool a which conatains two servers. But if the url contains "infoview", it gets forwarded to another pool, and redirected to servername that it is load balanced to and a uri "servername"/businessobjects/enterprise115/InfoView/default.htm .
So if I have server1 and server2 int the pool
if it gets lb to server1 we need to redirect to
server1/businessobjects/enterprise115/InfoView/default.htm
if it gets lb to server2 we need to redirect to
server2/businessobjects/enterprise115/InfoView/default.htm
I have been working on this and cant quite get it working. Thanks for your help.
- steve_88008
check this out:
https://devcentral.f5.com/tech-tips/articles/routing-traffic-by-uri-using-irule - RJ_77653
Thanks for the help, but that really was not what I was looking for. Really need to get the redirect at the node level here is the css config
Service is the node
service crystal-sw-crystalpr04-HO/DC
redirect-string "sw-crystalpr04/businessobjects/enterprise115/InfoView/default.htm"
Content is the virtual server
content crystal-prd-VM-HO/DC-redirect
vip address 10.1.4.25
redundant-index 15
add service crystal-sw-crystalpr04-HO/DC
add service crystal-sw-crystalpr06-HO/DC
advanced-balance sticky-srcip
flow-timeout-multiplier 75
primarySorryServer crystal-sw-crystalpr05-HO/DC-FO
protocol tcp
port 80
url "//businessobjects-infoview/*"
active - Arie
Altostratus
Are you saying that you need to redirect to another URL or that you want to select a specific node in the pool?
Just an observation: if the servers each serve a separate and distinct purpose I would consider using separate pools, if not separate VIPs. Otherwise your monitoring could easily lead to unexpected problems. - RJ_77653
I am going to set them up on 2 VIP's, to make it easier, but for the challenging one I just need to load balance to the two servers, but I also need it to redirected to
So the VIP points to server1 and server2 and I need the redirect to be
server1/businessobjects/enterprise115/InfoView/default.htm when it is sent to server1
server2/businessobjects/enterprise115/InfoView/default.htm when it is sent to server2
Thanks again for the help! - RJ_77653
Thanks again for the help! - PeteWhite
Employee
When you say redirect, do you mean that you want to send an HTTP Redirect to the client to point to the actual server? ie the server is not located behind the BIG-IP, the BIG-IP is just doing smart redirecting?
Or maybe the BIG-IP redirects to the new URL on a different VS on the BIG-IP that then load balances to pool A?
From your original post it seems that what you want to do is look at the incoming URI and if it contains X then send to server A and modify the URI to be XYZ.
In pseudocode this would be:
when HTTP_REQUEST if HTTP::URI contains "thelinkrpts" then pool A URI replace with "/businessobjects/enterprise115/InfoView/default.htm" elseif HTTP::URI contains "infoview" then pool B URI replace with "/businessobjects/enterprise115/InfoView/default.htm" else pool C endif
