Uzair1's avatar
Uzair1
Oct 17, 2019
Need Help with I-Rule
We have deployed F5 in Azure it has limitation that we can only deploy one Virtual server on it , we have deployed a Virtual Server with all service ports but it has both SSL Client and Server profiles on it to server https traffic we now want to deploy the Virtual server with port 80 because our back end application is running on port 80 , Becuse of the limitation of Virtual server in Azure F5 iam looking for a i-rule that can forward the traffic depending on the FQDN and disable both client and Server SSL and forward the traffic to appropriate pool based on the FQDN . I have tried this i-rule what i get empty response . Any help will be appreciated .
when HTTP_REQUEST
{ switch -glob -- [string tolower [HTTP::host]] {
 "seps1-tgt.paymentslab.ncr.com" {  SSL::disable  switch -glob -- [string tolower [HTTP::uri]] {       "/processor*" {            pool "tgt-dc1-trn"   }      }   } } }
when SERVER_CONNECTED {   if { $usessl == 0 } {   SSL::disable   }   }
  • Snl's avatar
    Snl
    its easier to use LTM traffic policy here rather than irule
    refer sample
    https://f5-agility-labs-adc.readthedocs.io/en/latest/class3/module6/lab6.html
    • Uzair1's avatar
      Uzair1
      ​Hi Snl ,
         This will not help me as I cannot create more than one Virtual server in F5 due to its license  limitation in Azure
      Uzair
    • Uzair1's avatar
      Uzair1
      ​Hi Eaa,
          Thanks I have did the same , But my VS has both Client and Server SSL profile and I have an I-rule that re-direct to appropriate pool based on the FQDN/DNS name , I want to Bypass this both Client and SSL profile and send the traffic to appropriate pool based on DNS name .
      Uzair
      • Uzair1's avatar
        Uzair1
        ​Want to Bypass client and Server SSL profile for http traffic .
