Jeni_42541's avatar
Jeni_42541
Jan 15, 2014
Need help to collect new SSL connections on LTM
Hi All,
Trying to collect new SSL connections on LTM at any given time.
bigpipe ssl stats -this gives the TPS connections that is present at the given time.
Wondering if there are any OIDs to poll the new SSL connections. As per http://support.f5.com/kb/en-us/solutions/public/6000/600/sol6644.html don't think so we track new connections. Correct me if I am wrong. Also checked https://devcentral.f5.com/wiki/iRules.tcp__collect.ashx to collect the TPS logs via irule, the data which I am trying to fetch is huge and will need to run on 20 + LTMs. Irule might complicate things. Can you guide me through this requirement.
Thanks! Jeni
  • Pool member:
                        Server Current Connections
                        walk
                        value
                        output
                        .1.3.6.1.4.1.3375.2.2.5.4.3.1.11
                        Server Max Connections
                        walk
                        value
                        output
                        .1.3.6.1.4.1.3375.2.2.5.4.3.1.9
                        Server Total Connections
                        walk
                        value
                        output
                        .1.3.6.1.4.1.3375.2.2.5.4.3.1.10
    pool:
                        Server Maximum Connections
                        walk
                        value
                        output
                        .1.3.6.1.4.1.3375.2.2.5.2.3.1.6
                        walk
                        value
                        output
                        .1.3.6.1.4.1.3375.2.2.5.2.3.1.7
                        walk
                        value
                        output
                        .1.3.6.1.4.1.3375.2.2.5.2.3.1.8
    VS - Client side:
    Client Total Connections
            walk
            value
            output
            .1.3.6.1.4.1.3375.2.2.10.2.3.1.11
            Client Current Connections
            walk
            value
            output
            .1.3.6.1.4.1.3375.2.2.10.2.3.1.12
    connection type depends on your profile, if it is ssl you see the amount of ssl connections
