Need help on uri redirection i-rule
if {([HTTP::uri] starts_with "/useradmin") or ([HTTP::uri] starts_with "/sld") or ([HTTP::uri] starts_with "/nwa") or ([HTTP::uri] starts_with "/index.html") or ([HTTP::uri] starts_with "/irj/go/km/docs/documents") or ([HTTP::uri] starts_with "/monitoring/SystemInfo") or ([HTTP::uri] starts_with "/uddiclient") or ([HTTP::uri] starts_with "/webdynpro/welcome/Welcome.jsp") or ([HTTP::uri] starts_with "/wsnavigator")} {
HTTP::redirect "https://straight2axis.axisbank.co.in/irj/portal"}
However, the user's requirement now states that any incoming request only to these specific context paths:
/irj/go/km/docs/documents/AxisBank/* OR /irj/go/km/docs/documents/AxisBank/^
SHOULD NOT get redirected to the Login Page, it sholud fwd as it is
For that many If's, I'd move to a switch statement. Plus it gives you an easy way to OR conditionals. The following will redirect to the straight2axis.axisbank.co.in link. The other two requests ( I was guessing what you wanted to do with the "^" in the second URL btw. You may have to change that ) will pass through as is. All other URI's will pass through as well unless you put something in the default case. If the default case is a passthrough though, you can just omit the two "OR'd" conditions as they will do the same thing as all other URIs.
when HTTP_REQUEST { switch -glob [HTTP::uri] { "/useradmin*" - "/sld*" - "/nwa*" - "/index.html*" - "/irj/go/km/docs/documents*" - "/monitoring/SystemInfo*" - "/uddiclient*" - "/webdynpro/welcome/Welcome.jsp*" - "/wsnavigator*" { HTTP::redirect "https://straight2axis.axisbank.co.in/irj/portal" } "/irj/go/km/docs/documents/AxisBank/*" - "/irj/go/km/docs/documents/AxisBank/^*" { Do nothing - allow to pass through } default { TODO: Do something for all other requests here } } }Hope this helps...
-Joe
- Kevin_Stewart
Employee
I would first highly recommend throwing all of those URIs into a data group. So if you did that, you might try something like this:
when HTTP_REQUEST { if { [string tolower [HTTP::uri]] starts_with "/irj/go/km/docs/documents/AxisBank" } { return } elseif { [class match [string tolower [HTTP::uri]] starts_with my_uri_dg] } { HTTP::redirect "https://straight2axis.axisbank.co.in/irj/portal" } } - Torti
Cirrus
hi,
- use switch instead of if! Its easier to read and a little bit faster. link text
- you have to put everything in the right order. "/irj/go/km/docs/documents/AxisBank/" will be covered by "/irj/go/km/docs/documents/". So if you want to do other things (no redirect) with every request containing AxisBank, you have to select it first.
try this one:
switch -glob [HTTP::uri] { "/irj/go/km/docs/documents/AxisBank/*" { do nothing - let through } "/irj/go/km/docs/documents/*" - "/useradmin*" - "/uddiclient" - "..." { HTTP::redirect "https://straight2axis.axisbank.co.in/irj/portal" } }regards
- Arie
Altostratus
Rumor has it that Switch is faster up to about 100 entries. Also, keep in mind that updating datagroups results in errors for a brief period of time. You can prevent this by first verifying that the group exists (it gets deleted and re-created during an update), but depending how the group is updated not all entries are immediately present in the datagroup.
- Arie
Altostratus
Lastly, I noticed that you're using a 302 (Found). If you're confident that you will always want to redirect to the new URL I'd recommend a 301:
HTTP::respond 301 Location "https://straight2axis.axisbank.co.in/irj/portal" - acgutierrez_123
Hi Kris, I'm trying to do exactly the same as you want to do with this irule, does it work for you?
