Need help on understanding Persistence Irule
Hi Guys ,
Can someone please explain me in details how this Persistence Irule works .
ltm rule U_Persistence {
set defaultPool [LB::server pool]
if { [regexp -nocase {UUID=([a-zA-Z0-9+-]+)} [HTTP::uri] matched uuid] == 1 } {
log local0. "1 pool: $defaultPool"
log local0. "uuid: $uuid"
pool $defaultPool
persist uie $uuid 900
pool $defaultPool
persist source_addr 255.255.255.255 900
log local0. "2 pool_else: $defaultPool"
- Oscar_Pucheta
Cirrus
Hi Sajan,
The irule search for the value after the uuid parameter in the URL, if the irule finds that (for example uuid=1234), then it wll use the uuid (1234) to persist the connection. The subsequent request using the same uuid will get redirected to the same server. if the irule doesn't find the uuid in the URL, then it just persist the connection based on the source IP address of the client. On both scenarios, the timeout is 900 seconds. Hope it helps.
Best Regards,
Oscar Pucheta
https://www.australtech.net
https://www.linkedin.com/in/npucheta/
