john_waterworth
Dec 21, 2012Need help converting CSS to LTM
I have the following config on a CSS that I need to migrate to an LTM
content pdc-ehis-usinode
port 80
protocol tcp
url "//ehis.ebscohost.com/conn/*" (match traffic for this rule)
vip address 10.1.10.54
string range 5 to 13 (where to match the string)
advanced-balance url
add service usinode101-ext
add service usinode102-ext
add service usinode103-ext
add service usinode104-ext
active
service usinode101-ext ip address 10.1.60.72 protocol tcp port 80 keepalive type tcp keepalive port 80 string node101 active
- What_Lies_Bene1
I assume you're OK with the VS, Pool and Node setup and it's the load balancing portion you want to replicate. If so, this articles covers it nicely: https://devcentral.f5.com/tech-tips/articles/pageid/149/articleid/135/articletype/articleview.UNR33Tmmv1V
