Need Documentation
Hi Team,
Recently we deployed F5 APM for one of our customers. we need to prepare documentation. Kindly send us documentation template.
- Seth_Cooper
Employee
What are you trying to document? Are you trying to document how to manage the BigIP and APM or are you wanting to document helpdesk processes for end user support?
Have you seen this Operations Guide?
https://support.f5.com/kb/en-us/products/big-ip_apm/manuals/product/f5-apm-operations-guide.html
-Seth
- Gowthaman_Ganap
Hi Seth Cooper, Thanks for your reply.. I want to document the configuration and deployment that we have done over there. For that i need document Template.
- Seth_Cooper
Employee
I'm not aware of any "document template" that is available. You can export the config via a scf and the config would be documented by the config file.
https://support.f5.com/kb/en-us/solutions/public/13000/400/sol13408.html
If that will not work then you will probably have to create your own template based on what information is important to document.
-Seth
- Gowthaman_Ganap
Dear Seth,
Thanks for your update.. Let me check..
