Greg_33129's avatar
Greg_33129
Jul 09, 2009
Need assistance with a URL Replacement
All,
We are using 1500's with version 9 in a pair. I have taken an urgent request for the F5 to intercept a URL and take the user to a different site (while maintaining the original URL. Here is what I need to do:
When someone types this into their browser:
https://test.secure.mycompany.com/apps/bmv/irecords/
I need the irule to take them to:
http://newserver.mycompany.com:47080/apps/bmv/irecords/
1. Not sure if the trailing slash is needed, But I need to reroute to a differnt server with everything after irecords/ remaining the same.
2. It needs to show the user the original url
"https://test.secure.mycompany.com/apps/bmv/irecords/" and everything that comes after it.
I have searched the Forums and haven't found an article that addresses all of these aspects.
Kind Regards,
Greg
  • hoolio's avatar
    hoolio
    Hi Greg,
    You can use the ProxyPass iRule to proxy an external hostname/URI to an internal hostname/URI. The IP and TCP layer translations are handled by your VIP/pool configuration. The VIP would be defined on an external IP:443 and the pool members would be defined on internal IPs:47080. The ProxyPass rule will rewrite the host and URIs in the request and optionally rewrite the response headers and payload. There is a v10 example and one for 9.x:
    http://devcentral.f5.com/Wiki/default.aspx/iRules.CodeShare
    Aaron
  • hoolio's avatar
    hoolio
    Actually, if you only need to replace the Host header in requests and the app uses all local references (no references in response headers or payload to newserver.mycompany.com:47080, you can use a simple iRule:
         Rewrite host header
        HTTP::header replace Host "newserver.mycompany.com:47080"
    Again, the load balancing will handle the IP and port translation from the VIP IP:port to the pool member IP and port.
    You might try testing this option first before delving into the much more functional (and complicated) ProxyPass rule.
    Aaron
