NAT (not SNAT) not preserving client source port
Hello ,
recently we've migrated our bigip-3600 to a new bigip400 platform. Everithing is working correctly except NATs.
Something has changed in the way ltm work with NATs.
With version 9.4.6 ltm preserved the client source port and after 300 seconds timeout it deleted connection from table, but when new traffic arrived it recreated the session again and the connection keep working without interruption.
With version 11.5.1 ltm doesn't preserve client source port, it changes it. Another problem is that after timeout it doesn't create again the sesion so connectionis interrupted.
has anybody experienced the same situation?
Thanks in advance
- nitass
Employee
i understand it is due to hardware architecture and cmp. source port has to be changed to make return traffic going to the same tmm.
sol14358: Overview of Clustered Multiprocessing (11.3.0 and later)
https://support.f5.com/kb/en-us/solutions/public/14000/300/sol14358.html
there is request for enhancement to implement preserve-strict for nat configuration but it is not yet implemented.
ID441079 - [RFE] Add "preserve-strict" option to NAT object to preserve source port strictly
anyway, could it be possible to use virtual server with preserve strict instead of nat?
sol11003: Configuring source port preservation for virtual servers
https://support.f5.com/kb/en-us/solutions/public/11000/000/sol11003.html
- swtbeer
Thanks for your answer nitass.
do you know how can i "simulate" a NAT using a virtual server?
Regards Javi
- StephanManthey
Nacreous
Hi Javi, it depends, how you are using it: In case of inbound only traffic only, a virtual server (PerformanceL4, all protocols) with a single member pool (both configured for port 0) will handle it. In case of outbound traffic a wildcard network virtual server (ForwardingIP) configured for port 0 with a SNATpool containing the NAT address will handle the traffic. As with your current NAT configuration network routes will be required to reach non-locally attached targets. For bi-directional traffic you will need both configuration elements. Thanks, Stephan
- swtbeer
Thank you Stephan.
It seems to be quite complicated only for doing a NAT but i'm going to try it.
Regards Javi
- StephanManthey
Nacreous
I´m wondering, what kind of application is so sensitive about preserving the source port?
- swtbeer
Hi Stephan ,
the important point here isn't the client source port. What I need is that ltm keep the NAT connection working after 300 seconds timeout. It seems that in versión 9, NAT connections used "lost initiation" feature adding again the connection to the connection table without requiring a SYN packet. For this to work correctly is necessary that the client source port keeps unchanged.
In version 11 , ltm drops the connection without sending RST and it doesn't add it again when new trafic comes. I think is related to the client source port is changed.
I don't know if I'm explaining fine.
Regards
- nitass
Employee
this is just a test. it may not be fully correct.
platform and version root@(B4200-R76-S10)(cfg-sync Standalone)(Active)(/Common)(tmos) show sys hardware | grep -A 4 Platform Platform Name BIG-IP 4200 BIOS Revision OBJ-0433-xx Build: 2.02.171.0 05/02/2014 Base MAC 00:23:e9:8d:03:80 root@(B4200-R76-S10)(cfg-sync Standalone)(Active)(/Common)(tmos) show sys version | grep -A 5 Product Product BIG-IP Version 11.5.1 Build 8.0.175 Edition Hotfix HF8 Date Mon Feb 9 00:49:11 PST 2015 nat [root@B4200-R76-S10:Active:Standalone] config tmsh list ltm nat test ltm nat test { inherited-traffic-group true originating-address 200.200.200.101 traffic-group traffic-group-1 translation-address 101.101.101.101 } trace [root@B4200-R76-S10:Active:Standalone] config tcpdump -nni 0.0 -s0 port 80 tcpdump: verbose output suppressed, use -v or -vv for full protocol decode listening on 0.0, link-type EN10MB (Ethernet), capture size 65535 bytes 03:48:42.252624 IP 200.200.200.101.58123 > 101.101.101.6.80: S 2652003240:2652003240(0) win 5840 in slot1/tmm3 lis= 03:48:42.252683 IP 101.101.101.101.30203 > 101.101.101.6.80: S 2652003240:2652003240(0) win 5840 out slot1/tmm3 lis=/Common/test,SRC_NAT [root@B4200-R76-S10:Active:Standalone] config tcpdump -nni 0.0 -s0 port 80 tcpdump: verbose output suppressed, use -v or -vv for full protocol decode listening on 0.0, link-type EN10MB (Ethernet), capture size 65535 bytes 03:48:53.868216 IP 101.101.101.6.56619 > 101.101.101.101.80: S 3744296679:3744296679(0) win 5840 in slot1/tmm3 lis= 03:48:53.868298 IP 101.101.101.6.11327 > 200.200.200.101.80: S 3744296679:3744296679(0) win 5840 out slot1/tmm3 lis=/Common/test,DST_NAT virtual server for outbound [root@B4200-R76-S10:Active:Standalone] config tmsh list ltm virtual outbound ltm virtual outbound { destination 0.0.0.0:0 ip-forward mask any profiles { fastL4 { } } source 200.200.200.101/32 source-address-translation { pool snat_101.101.101.101 type snat } source-port preserve-strict translate-address disabled translate-port disabled vlans { internal } vlans-enabled vs-index 4 } [root@B4200-R76-S10:Active:Standalone] config tmsh list ltm snatpool snat_101.101.101.101 ltm snatpool snat_101.101.101.101 { members { 101.101.101.101 } } trace [root@B4200-R76-S10:Active:Standalone] config tcpdump -nni 0.0 -s0 port 80 tcpdump: verbose output suppressed, use -v or -vv for full protocol decode listening on 0.0, link-type EN10MB (Ethernet), capture size 65535 bytes 03:39:19.646364 IP 200.200.200.101.58120 > 101.101.101.6.80: S 800989615:800989615(0) win 5840 in slot1/tmm0 lis= 03:39:19.646591 IP 101.101.101.101.58120 > 101.101.101.6.80: S 800989615:800989615(0) win 5840 out slot1/tmm0 lis=/Common/outbound virtual server for inbound [root@B4200-R76-S10:Active:Standalone] config tmsh list ltm virtual inbound ltm virtual inbound { destination 101.101.101.101:0 mask 255.255.255.255 pool pool_200.200.200.101 profiles { fastL4 { } } source 0.0.0.0/0 source-port preserve-strict translate-port disabled vlans { external } vlans-enabled vs-index 6 } [root@B4200-R76-S10:Active:Standalone] config tmsh list ltm pool pool_200.200.200.101 ltm pool pool_200.200.200.101 { members { 200.200.200.101:0 { address 200.200.200.101 } } } trace [root@B4200-R76-S10:Active:Standalone] config tcpdump -nni 0.0 -s0 port 80 tcpdump: verbose output suppressed, use -v or -vv for full protocol decode listening on 0.0, link-type EN10MB (Ethernet), capture size 65535 bytes 03:41:53.120330 IP 101.101.101.6.56612 > 101.101.101.101.80: S 3185620727:3185620727(0) win 5840 in slot1/tmm2 lis= 03:41:53.120856 IP 101.101.101.6.56612 > 200.200.200.101.80: S 3185620727:3185620727(0) win 5840 out slot1/tmm2 lis=/Common/inbound - nitass
Employee
it was not dropped here. i used hping to send push flag when connection was not in connection table.
e.g.
version [root@B4200-R76-S10:Active:Standalone] config tmsh show sys version | grep -A 5 Product Product BIG-IP Version 11.5.1 Build 8.0.175 Edition Hotfix HF8 Date Mon Feb 9 00:49:11 PST 2015 nat [root@B4200-R76-S10:Active:Standalone] config tmsh list ltm nat test ltm nat test { inherited-traffic-group true originating-address 200.200.200.101 traffic-group traffic-group-1 translation-address 101.101.101.101 } [root@B4200-R76-S10:Active:Standalone] config tmsh list ltm virtual [root@B4200-R76-S10:Active:Standalone] config client [root@centos101 ~] hping -P -c 1 -d 100 101.101.101.6 -p 80 HPING 101.101.101.6 (eth1 101.101.101.6): P set, 40 headers + 100 data bytes len=46 ip=101.101.101.6 ttl=63 DF id=0 sport=80 flags=RA seq=0 win=0 rtt=1.3 ms trace [root@B4200-R76-S10:Active:Standalone] config date; tmsh show sys connection Tue Mar 10 03:59:25 PDT 2015 Sys::Connections Total records returned: 0 [root@B4200-R76-S10:Active:Standalone] config tcpdump -nni 0.0 -s0 port 80 tcpdump: verbose output suppressed, use -v or -vv for full protocol decode listening on 0.0, link-type EN10MB (Ethernet), capture size 65535 bytes 03:59:28.959071 IP 200.200.200.101.1760 > 101.101.101.6.80: P 1126296173:1126296273(100) win 512 in slot1/tmm3 lis= 03:59:28.959134 IP 101.101.101.101.1476 > 101.101.101.6.80: P 1126296173:1126296273(100) win 512 out slot1/tmm3 lis=/Common/test,SRC_NAT - swtbeer
Hi Stephan ,
ii think hping opens a new connection each time you execute it . My problem is with connections that should be keep openned for more than 300 seconds without activity.
i'm trying to get some examples of my problem to post them here. I hope to achieve.
Regards
