Anupam_Gupta_55's avatar
Anupam_Gupta_55
Apr 27, 2006
Multiple ssl certs on same virtual server using iRule?
I wanted to find out if anyone has used iRule to support multiple sites on the same virtual server.
Basically something like a virtual server in apache....my requirement is to use the same vs and load multiple ssl certs based on the domain name.
any ideas how to do so using an iRule?
thanks in advance
  • Tom_Spector_50's avatar
    Tom_Spector_50
    Historic F5 Account
    You can use a wildcard certificate on the VS for all the hosts in the same domain but not different domains on the same VS
