Leslie_South_55's avatar
Leslie_South_55
Jan 31, 2008
Multiple matchclass + "if" AND "if not"
I am trying to use both an 'if' and an 'if not' statement where both statements are looking at 2 different external class files. Here is the rule:
      log local0 "requested [HTTP::uri]"
   if {not [matchclass [string tolower [HTTP::uri]] contains $::uri_block] } {
    if {[matchclass [IP::client_addr] equals $::allowed] } {
      log local0.  "Valid Packet: [IP::client_addr] - [HTTP::uri] forwarding traffic"
 } else  {
      log local0. "Invalid Packet: [IP::client_addr] - [HTTP::uri] discarding"
     discard
it does not seem to be reading the entire rule, as I get log entries as follows:
: Valid Packet: 10.2.6.31 - /AeXHD/user/default.aspx forwarding traffic
where the "user" is defined in the uri_block class (what I am trying to block access to)
and 10.2.6.31 is defined in the allowed class (one of the allowed client IP's)
Any help much appreciated.
-L
  • I can do this with 2 rules on the VS, and I guess that is OK, just was trying to get it all in one rule.
    -L
  • hoolio's avatar
    hoolio
    Can you try wrapping the conditional test you're not'ing in parens?
       if {not ([matchclass [string tolower [HTTP::uri]] contains $::uri_block])} {
          } else  {
             discard
    Aaron
  • Aaron,
    I added the parens as per your suggestion, but still no go. Not sure if this is the app or not, but I get 4 HTTP_REQUESTs that include text I am tring to restrict before the valid packet log statement is getting generated, here is the log
    : requested /aexhd/user
    : requested /aexhd/user/
    : requested /AeXHD/css/styles.css
    : Valid Packet: 10.2.6.31 - /AeXHD/css/styles.css forwarding traffic
    my uri_block class file has "user" defined
    -L
  • hoolio's avatar
    hoolio
    Actually, I think I missed part of what you're trying to do. Do you want to allow the request if the requested URI is not in the blocked URI class or if the client IP is in the allowed IP's class; and drop all other requests?
    If so, I think this should work and be slightly clearer:
       if {not ([matchclass [string tolower [HTTP::uri]] contains $::uri_block]) or [matchclass [IP::client_addr] equals $::allowed]} {
       } else  {
          discard
    Aaron
  • I need to match on BOTH, so I changed the 'or' to 'and'...now I'm in buisness...funy thing is I tried the AND between the if statements on my first attempt and ketp getting all sorts of syntax errors, must have been the misplaced parens.
    Thanks Aaron for your assistance.
    -L
