Mic_108850
Altostratus
Jun 01, 2010multi domains / invalidations
HI,
I have one web_app accepting 2 host headers:
prod.domain.com
preprod.domain.com
When i need to invalidate some contents only on the preprod.domain.com ( the contents could be the same between prod and preprod),
What is the easy way to specify it? is webacc doing difference of content invalidation with hostname specified?
Thks
- Mic_108850
Altostratus
Hello,
no body to help me on this issue?
Thsk - Moorthy_63564
Dear Mic,
As per your question what i have understand is you have the one web server,you can access the application by using that Domain Names right? The solution is you can go with APM, That is Access Policy Manger you can configure the policy based on DNS,USER.......If u want to know more please go through the APM guides..
Regards,
Moorthy.T
[email protected]
