Walter_Kacynski's avatar
Walter_Kacynski
Apr 29, 2016
mptcp-mobile-optimized and Hardware SYN Cookie Protection
Does anyone know why the TCP protocol profile mptcp-mobile-optimized ships with Hardware SYN Cookie Protection disabled? It is still enabled on tcp-mobile-optimized.
Here is a copy of my two profiles, which should be the default:
ltm profile tcp mptcp-mobile-optimized {
    abc disabled
    app-service none
    congestion-control illinois
    defaults-from tcp
    delay-window-control disabled
    delayed-acks disabled
    dsack disabled
    ecn enabled
    hardware-syn-cookie disabled
    init-cwnd 16
    limited-transmit enabled
    mptcp enabled
    nagle enabled
    pkt-loss-ignore-burst 0
    pkt-loss-ignore-rate 0
    proxy-buffer-high 131072
    proxy-buffer-low 131072
    rate-pace enabled
    receive-window-size 131072
    reset-on-timeout disabled
    selective-acks enabled
    send-buffer-size 262144
    slow-start enabled
    timestamps enabled
ltm profile tcp tcp-mobile-optimized {
    abc disabled
    app-service none
    congestion-control high-speed
    defaults-from tcp
    dsack disabled
    ecn enabled
    init-cwnd 16
    nagle enabled
    send-buffer-size 131072
    slow-start enabled
    timestamps enabled
  • Hello,
    This is a compatibility issue at the specification level as the M-TCP stack is not designed to support syn-cookie protection. I think that if you activate syn-cookie protection on a m-tcp enabled system, you expose yourself to many false positives and TCP retransmission.
