Julio_Navarro
Jan 16, 2019Move VIPs from the Common partition to another partition, same box
Hi!
I am looking for a way - LESS destructive and intrusive - on moving 100+ VIPs (with its pools) from the Common partition to another partition.
Please advise
J
- stan_piron
Cumulonimbus
To move to a different partition, you have to remove all objects from common partition..
First copy configuration (tmsh she’ll) :
list ltm pool one-line list ltm virtual one-lineThen move to partition
cd /part1Remove the configuration to move(try with one non critical virtual server), then import the configuration in new partition
load sys config merge from-terminalPaste the configuration to load the end with CTRL-D
