John_Stewart_47's avatar
John_Stewart_47
Feb 10, 2009
Mount USB memory stick
not sure where this should go, but will try here.
Is there a document our procedure to mount a usb memory stick on an LTM running 9.3.1.
Purpose would be to move files back and forth to a device that may be off line.
I am not asking about booting from USB CDROM. Looked at askf5 and could not find anything.
Thanks!
  • James_Quinby_46's avatar
    James_Quinby_46
    Historic F5 Account
    jrstewart -
    The drive will need to be formatted with FAT or FAT32. Do the following:
    1. Plug the drive into the USB slot
    2. type:
    dmesg | grep "SCSI device"
    ...and make note of the device identifier (which should be 'sda' or something along those lines)
    3. type:
    mkdir /mnt/usbdrive
    4. then:
    mount -t vfat /dev/sda /mnt/usbdrive
    5. finally:
    cd /mnt/usbdrive
    ...which should put you into the USB drive. When you need to pull the thumbdrive, do:
    cd /; umount /dev/sda
  • hoolio's avatar
    hoolio
    The only reference I could find is from the release notes:
    https://support.f5.com/kb/en-us/products/big-ip_ltm/releasenotes/umd_install_9_4_x.htmlusbmedia
    * USB Consortium as a Mass Storage Device certified
    * USB version 2.0 or later
    * 512 MB minimum capacity, recommended 1 GB capacity
    The device capacity and capabilities are described in the following table.
    Note: While smaller capacity devices are supported, we recommend using a device with at least 1 GB capacity.
    If a key works for the installation, I'd expect it would be mountable after installation.
    Aaron
