ykurtz_100350's avatar
ykurtz_100350
Nov 28, 2007
MOSS 2007 SSL Offloading Help
I have a F5 with the properly configured iRule.
Does anyone have any guidelines on how to properly configure Alternate Access Mappings on the MOSS side to support SSL Offloading?
I have successfully done this before using ISA 2006, but have yet to succeed with F5. The http to https stuff is working, but certain functionality (i.e. creating new lists/libraries) fails due to an incorrect AAM setup.
Thanks.
  • Ryan_Korock_46's avatar
    Ryan_Korock_46
    Historic F5 Account
    ykurtz,
    I'm not sure why it is failing. However I have typically had good luck changing the AAM from
    http://servername
    to
    https://www.siteurl.com
    I know you posted a while ago, but if you're still having problems, let me know and we'll figure it out.
    -Ryan
