Alexey_02_15975's avatar
Alexey_02_15975
Jun 04, 2014
Monitoring LB resopenses count for each HTTP code
Hello!
Device: big-ip ltm 1600 series. I use zabbix to monitor device. I have LB configured on it, and I have to make check of count of particular HTTP codes responses. Is it possibe?
Ex: member1_http_response_200 = x member1_http_response_400 = x member1_http_response_501 = x member1_http_response_503 = x etc..
Load Balancer configured with the device:
monitor http_%NODE%monitor {
   defaults from http
   recv "%STRING%"
   send "GET %URL%"
pool %NODE% {
   action on svcdown reselect
   monitor all tcp
   members {
      %MEMBER1%:http {}
      %MEMBER2%:http {}
      %MEMBER3%:http {}
virtual %NODE% {
   snat automap
   pool %NODE%
   destination %LB-VIP%:http
   ip protocol tcp
Monitoring use SNMP to poll the device
  • I have to make check of count of particular HTTP codes responses. Is it possibe?
    i believe there are a couple of ways. this is an example of istats.
    Introduction to iStats Part 1: Overview by Colin Walker
    https://devcentral.f5.com/articles/introduction-to-istats-part-1-overview.U47i8CjNyCQ
     config
    root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm virtual bar
    ltm virtual bar {
        destination 172.28.24.10:80
        ip-protocol tcp
        mask 255.255.255.255
        pool foo
        profiles {
            http { }
            tcp { }
        rules {
            qux
        source 0.0.0.0/0
        source-address-translation {
            type automap
        vs-index 41
    root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm rule qux
    ltm rule qux {
        when HTTP_RESPONSE {
      ISTATS::incr "ltm.virtual /Common/bar c HTTP_[HTTP::status]" 1
     stats (User-defined section)
    root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) show ltm virtual bar
    Ltm::Virtual Server: bar
    Status
      Availability     : unknown
      State            : enabled
      Reason           : The children pool member(s) either don't have service checking enabled, or service check results are not available yet
      CMP              : enabled
      CMP Mode         : all-cpus
      Destination      : 172.28.24.10:80
    Traffic                             ClientSide  Ephemeral  General
      Bits In                               575.2K          0        -
      Bits Out                                1.1M          0        -
      Packets In                            1000.0          0        -
      Packets Out                           1000.0          0        -
      Current Connections                        0          0        -
      Maximum Connections                      100          0        -
      Total Connections                        200          0        -
      Min Conn Duration/msec                     -          -     4.0K
      Max Conn Duration/msec                     -          -     4.6K
      Mean Conn Duration/msec                    -          -     4.0K
      Total Requests                             -          -      200
    SYN Cookies
      Status                         not-activated
      Hardware SYN Cookie Instances              0
      Software SYN Cookie Instances              0
      Current SYN Cache                          0
      SYN Cache Overflow                         0
      Total Software                             0
      Total Software Accepted                    0
      Total Software Rejected                    0
      Total Hardware                             0
      Total Hardware Accepted                    0
    CPU Usage Ratio (%)
      Last 5 Seconds                             0
      Last 1 Minute                              0
      Last 5 Minutes                             0
    User-defined  Value
      HTTP_200  100
      HTTP_302  100
    • Alexey_02_15975's avatar
      Alexey_02_15975
      Colin, do you know is it possible to publish this values to SNMP OIDs? Or may be , it is possible to share it with HTTP or some other interface (the goal is to push it to zabbix... no... to let zabbix to pull this values;) )
      Alexey_02_15975
      Colin, we observered, that we used software version 10.2 , and this version doesn't support ISTATS. Unfortunately we can't upgrade to 11.0 version. Can you suggest another solution? Appreciate your time and thank you in advance!
     config
    ltm virtual bar {
        ip-protocol tcp
        pool foo
        profiles {
            http { }
            tcp { }
        rules {
            qux
        source 0.0.0.0/0
            type automap
        vs-index 41
    ltm rule qux {
    Status
      State            : enabled
      CMP              : enabled
      CMP Mode         : all-cpus
      Bits In                               575.2K          0        -
      Bits Out                                1.1M          0        -
    SYN Cookies
      Current SYN Cache                          0
      Total Software                             0
      Total Hardware                             0
    CPU Usage Ratio (%)
      Last 5 Seconds                             0
      Last 1 Minute                              0
      Last 5 Minutes                             0
    User-defined  Value
      HTTP_200  100
      HTTP_302  100
      Alexey_02_15975
      Alexey_02_15975
  • do you know is it possible to publish this values to SNMP OIDs?
    unfortunately, it is not available through snmp yet. there is rfe. you may open a case to expedite the process.
    ID380761 - RFE: export iStats via SNMP
    in the meantime, you may try stats profile instead but stats has to be predefined (not like istats which can be created on the fly).
    10.0, statistics profiles are not fully CMP compatible. Each TMM instance uses a separate instance of the statistic profile. The cumulative counts are shown in the GUI and when polled via SNMP.
    CMP Compatibility
    https://devcentral.f5.com/wiki/iRules.cmpcompatibility.ashx
