Matthew_Hutchin's avatar
Matthew_Hutchin
Jan 21, 2014
Monitoring ASM, AFM, APM, and AAM
Does anyone know if you can monitor these with cacti?
Matt
  • Hamish's avatar
    Hamish
    You can monitor anything. Either with the standard MIB's or if there's a parameter you want to monitor that isn't included in the standard SNMP MIB's then you can write custom server side code that is called from snmpd for your own OID's.
    H
