Stephane_Bernar
Aug 07, 2008Monitoring and ICMP
Hi all,
hopefully a quick question with an easy answer!. I have two nodes [i.e Two windows 2003 server] which were monitored using the icmp health monitor [This is monitoring the box itself and not the webserver on it]. However, our security team is not happy with it and have asked that we enable the Windows Firewall on that machine and thus turn off icmp traffic.
Now i was trying another health monitor [tcp echo] but with the Windows 2003 Firewall activated the Health Monitor is marking the member has down. So the question is: on which port the tcp echo operates in order for me to enable this port on the window firewall?
Thank is advance.
Stephane
- James_Quinby_46Historic F5 AccountStephane -
The echo service runs on TCP port 7, but there needs to be an echo server running there for the monitor to succeed. Telnet to your server on port 7 and see if you get a connection. If you do, see if input you provide is echoed back to the screen. If it is, you should be in business.
