Perry_Wagner_11's avatar
Perry_Wagner_11
17 years ago
Monitoring Active/Standby failover
Is there a way anyone has found to get an email notification if a redundant pair failover of BigIP occurs?
thanks
  • Edit /etc/alertd/alert.conf, bold lines added to the default file contents
      alert BIGIP_SOD_SODERR_SOD_STANDBY {
              snmptrap OID=".1.3.6.1.4.1.3375.2.4.0.14";
              lcdwarn description="Unit going standby." priority="0"
              email toaddress="LTM-alert@mydomain.com"
              fromaddress="LTM1@mydomain.com"
              body="LTM Failover event occured: Unit going to standby"
      alert BIGIP_SOD_SODERR_SOD_ACTIVE {
              snmptrap OID=".1.3.6.1.4.1.3375.2.4.0.15";
              lcdwarn description="Unit going Active." priority="0"
              body="LTM Failover event occured: Unit going to active"
    This assumes you have postfix configured to forward mail to your relay.
    For more details on alertd, Click here
    For details on configuring postfix, Click here
  • Hamish's avatar
    Hamish
    Small nit... It should be
               lcdwarn description="Unit going standby." priority="0";
               lcdwarn description="Unit going Active." priority="0";
    Note the ';' (Semi-Colon) between the second alert (lcdwarn) and the third (email). (You need a semi-colon between each alert). Not obvious unfortunately. The alertd just logs into ltm that there's a problem at the email line otherwise.
  • shafiul's avatar
    shafiul
    While configured this, we are getting the below email "Subject: 010c0018". Is there any way we can change the subjet of the email?
    From: root [mailto:root@lb-lab1.test.com] Sent: Tuesday, June 5, 2018 4:58 PM To: mazam@test.com Subject: 010c0018
