flomkrl_29950's avatar
flomkrl_29950
Feb 29, 2008
Monitor http - CR LF add by F5
Hello,
I'm writing a POST HTTP to test a SOAP services. It is the same as a POST request send by the soap client (i compare it with tcpdum trace). The only difference is that the F5 add "CR LF" on the end (0d 0a). I think, it cause the IIS server to consider my request as a bad http request!
How to indiquate to the F5 to do not add this "CR LF" ?
Thanks for your expertise;
regards,
Flo;
  • hoolio's avatar
    hoolio
    I don't think there is anyway to avoid the extra \r\n that the monitoring daemon adds to the send string. It might have been viewed as a feature at some point, but obviously it creates problems with POST requests that have a body as RFC's state there shouldn't be any content past the content-length count.
    I'd suggest opening a case with F5 and find out whether there is already a CR requesting to have this tweak removed.
    To work around this issue, you could create an external monitor which references a perl or shell script. The shell script can open a connection using curl to send a POST request to the pool members. There are some good examples in the monitoring codeshare section.
    Aaron
