Modify priority of pool members using iRules
Hi all
I have an application which has the specific requirements:
- Two nodes in the pool.
- Send all requests to only one node during normal operation (hence using priority group activation).
- If the favoured node fails, then send all requests to the second node in the pool.
I understand there are implications here around availability, capacity etc, but the application team is aware of this and specifically want this setup. If the favoured node comes back online in the above example, the application team want the F5 to continue sending all requests to the second node to avoid outages.
My issue with the above is this:
- If the favoured node comes back online, it will be ignored and never used.
- Once this happens, if the second node in the pool fails (after it has already been selected as the sole node to use), traffic will not automatically be redirected back to the favoured node and no node will be selected.
I was thinking there may be some way to achieve the automatic redirection back the favoured node using "Action on service up", but sadly no event is available. Alternatively, it might be possible by programatically modifying the pool member priority values, but I'm not too sure of how this might be implemented.
Is there any way I can achieve the above functionality automatically on the F5?
- nitass_89166
Noctilucent
is single node persistence usable?
Single Node Persistence
https://devcentral.f5.com/wiki/irules.singlenodepersistence.ashx- Tony_Jarvis_132
Altostratus
That's a really interesting link and something I was unaware of, so thanks for posting! After reading through the entirety of the article, it seems this may not be suitable for situations requiring prioritisation of nodes within the pool though? This is the requirement we are facing, so we do need some way to cater for this. Are there any options with this in mind?
- nitass
Employee
Altostratus
- nitass
Employee
is LB::status useful (i.e. manually select pool member for the first request)?
e.g.
config root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm virtual bar ltm virtual bar { destination 172.28.24.10:80 ip-protocol tcp mask 255.255.255.255 pool foo profiles { http { } tcp { } } rules { qux } source 0.0.0.0/0 source-address-translation { type automap } vs-index 41 } root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm pool foo ltm pool foo { members { 200.200.200.101:80 { address 200.200.200.101 session monitor-enabled state up } 200.200.200.111:80 { address 200.200.200.111 session monitor-enabled state up } } monitor gateway_icmp } root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm rule qux ltm rule qux { when CLIENT_ACCEPTED { if { [persist lookup uie 1] ne "" } { persist uie 1 } else { if { [LB::status pool foo member 200.200.200.111 80] eq "up" } { pool foo member 200.200.200.111 80 } } } when SERVER_CONNECTED { persist add uie 1 } } persistence root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) show ltm persistence persist-records all-properties Sys::Persistent Connections universal - 172.28.24.10:80 - 200.200.200.111:80 ------------------------------------------------ TMM 0 Mode universal Value 1 Age (sec.) 6 Virtual Name /Common/bar Virtual Addr 172.28.24.10:80 Node Addr 200.200.200.111:80 Pool Name /Common/foo Client Addr 200.200.200.111 Local entry universal - 172.28.24.10:80 - 200.200.200.111:80 ------------------------------------------------ TMM 1 Mode universal Value 1 Age (sec.) 6 Virtual Name /Common/bar Virtual Addr 172.28.24.10:80 Node Addr 200.200.200.111:80 Pool Name /Common/foo Client Addr 200.200.200.111 Owner entry Total records returned: 2by the way, if you want to change pool member priority value, i think alertd or icall may be applicable.
Acton on Log - using the alertd deamon
https://devcentral.f5.com/wiki/advdesignconfig.Acton-on-Log-using-the-alertd-deamon.ashxiCall - All New Event-Based Automation System by Jason Rahm
https://devcentral.f5.com/articles/icall-all-new-event-based-automation-system
