flomkrl_29950
Mar 13, 2008MOCS SIP over SSL monitor
Hello;
I work actually on Microsoft Office Communicator load balancing project. For that, i need to monitor sip over ssl. For the moment i use a simple https monitor on the 5061 port, this is not a good monitor for that.
Is there any tools on the F5 to check correctly SIP over SSL ?
Thanks in advance,
Regards,
Flo,
- hoolio
As there isn't a default monitor that allows you to make generic non-HTTPS SSL requests, I think you'd need to create an external monitor which references a script. You could use bash and openssl's c_client (Click here) or perhaps a perl script to do this. You can check the Monitoring Codeshare (Click here) for example external monitors.
Aaron - flomkrl_29950
Thanks,
For info there is a sample script which permit to send data by ssl : http://devcentral.f5.com/SDK/sslvpn.public.pl.txt
here is the script i use now,
Regards,
Flo,
NODE=`echo ${1} | sed 's/::ffff://'`
PORT=${2}
PIDFILE="/var/run/`basename ${0}`.${NODE}_${PORT}.pid"
kill of the last instance of this monitor if hung and log current pid
if [ -f $PIDFILE ]
then
kill -9 `cat $PIDFILE` > /dev/null 2>&1
fi
echo "$$" > $PIDFILE
echo "" | /usr/bin/openssl s_client -host $NODE -port $PORT > /dev/null 2>&1
mark node UP if expected response was received
if [ $? -eq 0 ]
then
echo "UP"
fi
rm -f $PIDFILE
exit
