anthony_102289
Sep 15, 2010Mirroring to standby and iRule node/pool ability
Hi
I am unsure of a couple of aspects to do with iRules
- Are data group values mirrored to the standby?
- Are global variables/arrays mirrored to the standby?
- Are session sub-tables created in irules mirrored to the standby? [looks like yes, but just verifying]
- Can iRules add/remove and set ratios to node/pool members? [i think no, and need icontrol or external script]
Anthony
- anthony_102289
Hi
No reply to my question yet, can someone verify the following answers that I have come up with myself?
- Are data group values mirrored to the standby that are modified directly by irules?
No. Would need to "sync config" to be mirrored.
No.
Yes.
No, this would require icontrol or external script. [Script would also need to 'sync' config? to have standby running same nodes/ratios]
Anthony - The_Bhattman
Hi Anthony,
These are all correct responses to your questions.
To Further add to your last question
There are 2 directories where the configsync will pick up files (http://support.f5.com/kb/en-us/solutions/public/8000/500/sol8522.html). Otherwise you have to manually copy the External Scripts to the standby LTM.
Bhattman
