Martin_Podhola_'s avatar
Martin_Podhola_
17 years ago
minicom configuration for serial connection
Hello,
I am trying to diagnose a Viprion box, which has problem with loading. But I cannot connect a serial cable to the server. If I use default minicom configuration with 9600 baud rate, it returns non-sense result. So I would like to ask for configuration of minicom, which is standard for F5. (Baud rate, stop bits etc.)
Thanks so much
Martin Podhola
  • Martin: Check out Solution 7683 from ask.f5.com. It's got all the info you're after:
    bits per second [baud] 19200
    Data Bits 8
    Parity None
    Stop Bit 1
    Flow Control None
    -Matt
  • hoolio's avatar
    hoolio
    Hi Martin,
    The F5 default is 19200, but I haven't tested this with a Viprion:
    SOL7683: Connecting a serial terminal to a BIG-IP system
    https://support.f5.com/kb/en-us/solutions/public/7000/600/sol7683.html (Click here
    Aaron
