Microsoft Sharepoint 2010 External Monitor for NTLM Problem
I'm having a problem with an External Monitor I've created for Microsoft Sharepoint 2010, I'm trying to use the monitor posted on website http://www.thef5guy.com/blog/2010/08/sharepoint-2010-ntlm-and-big-ip-health-monitors/ I've just altered the curl section slightly.
Using the following curl command I can access the page if I input the variables so not sure why the monitor isn't working so any help much appreciated. A tcpdump on one of the pool members doesn't capture any packets so it suggests the monitor isnt functioning at all for some reason.
curl -H "Host: portalu" -fNs --ntlm -k --user "[email protected]:K******3" / "http://${IP}:${PORT}/Pages/Welcome.aspx" | grep -i "Microsoft" 2>&1 > /dev/null"
CODE
IP=echo ${1} | sed 's/::ffff://'
PORT=${2}
PIDFILE="/var/run/basename ${0}.${IP}_${PORT}.pid" if [ -f $PIDFILE ]
then
kill -9 cat $PIDFILE > /dev/null 2>&1
fi
echo "$$" > $PIDFILE
curl -H "Host: portalu" -fNs --ntlm -k --user "[email protected]:Kathryn2013" / "http://${IP}:${PORT}/Pages/Welcome.aspx" | grep -i "Microsoft" 2>&1 > /dev/null
if [ $? -eq 0 ] then
echo "UP"
fi
rm -f $PIDFILE
exit3 Replies
- Kevin_Stewart
Employee
If you execute the monitor script directly from the command line, passing IP and port as parameters, does it work?
- Dazzla_20011
Looking at the external monitor troubleshooting website if I do the following this should be correct. Apologies very little experience with the command line all through the GUI.
[root@f5-int-ltm1:Active] / /usr/bin/monitors/sharepoint_test 10.72.4.111 80 -bash: /usr/bin/monitors/sharepoint_test: No such file or directory
If I change it to include .sh the following is received.
root@f5-int-ltm1:Active] / /usr/bin/monitors/sharepoint_test.sh 10.72.4.111 80 bad interpreter: No such file or directory /bin/shI copied the script across using WINSCP and changed the permissions to 0777.
- Kevin_Stewart
Employee
A few things:
The external monitor profile actually expects these scripts in /config/monitors. You can put them elsewhere but then there's no guarantee they'll get backed up or synced.
Once inside the directory where the monitor script exists, type "ls" to see what its real name is. From that directory, try to execute the file with required parameters:
./sharepoint_test.sh 10.10.10.10 80
It may just be missing from your cut and paste, but the above script is missing the "!/bin/sh" on the first line, though technically it should probably be "!/bin/bash" since this is a Bash script. This line tells the system which interpreter to use.
