xhairs_248539
Sep 13, 2016MGMT-DHCP Settings w/o CLI?
Is there a way to do this without using the cli?
'tmsh modify sys global-settings mgmt-dhcp disabled'
- Lee_Sutcliffe
Nacreous
When you configure a static management IP, you automatically disable DHCP
System ›› Platform
Select "Manual" and configure a static IP
