ICM_38001
16 years agoMethods to determine whether an inbound connection is SSL or not
Hi Folks,
This is probably a bit of a newbie question.
I have two virtual servers lets call them vs_A_http and vs_B_https, assigned to myserver on one IP, both served by pool_webservers
I want to redirect all requests to http://myserver/secure to https://myserver/secure.
This is easy, the difficulty I am having is that I also want requests to https://myserver/secure to go to pool_securepaymentservers and all other https requests to go to pool_webservers (with bigip ssl offload.
I have managed to do this with one irule per virtual server. Like this:
irule applied to http server
if { [HTTP::uri] starts_with "/secure" } {
HTTP::redirect "https://[HTTP::host][HTTP::uri]"
irule applied to https server
pool pool_securepaymentservers
} Is there a better way to do this?
- L4L7_53191
This is a good way to do it. The only thing that stands out is that you may want to add an "else" clause to the SSL rule so you've got a fall back destination if the URI doesn't match - a default pool on the VS configuration will have the same effect, but I personally like to see it explicitly spelled out in the rule so the behaviors are easier to track.
-Matt - JRahm
Admin
you could consolidate into one iRule, applied to both, by evaluating the TCP::local_port contents:when HTTP_REQUEST { if { ([TCP::local_port] eq "443") and ([HTTP::uri] starts_with "/secure") } { pool pool_securepaymentservers } elseif { ([TCP::local_port] eq "80") and ([HTTP::uri] starts_with "/secure") } { HTTP::redirect "https://[HTTP::host][HTTP::uri]" } } - hoolio
To add to what Matt said, if you don't explicitly specify a pool in an else clause, you need to add a OneConnect profile to ensure subsequent requests on the same TCP connection go to the correct pool. For details see:
OneConnect with HTTP
http://devcentral.f5.com/wiki/default.aspx/AdvDesignConfig/oneconnect.html
Aaron
