Maximum Query String - F5 LTM
Hi ,
Yesterday we held up in the issue , AD team Testing one new application while importing the LCM export from browser ( port http ) it results with Attached error message . When we bypassed the LB its working , to Sort the cause of issue i tried by removing Cookie and Http profile but no symptoms to work .
Seems issue with Maximum Query string as error message Suggest .
Attached the Error file
Answers Much appreciated .
- giltjr
I don't think the F5 has a limit on the length of the URI. Have you done a packet capture on the F5 to see what the input to the F5 is and what the F5 passes on?
Do you have any iRules that could be altering the data and increasing the size as it passes through the F5?
