spalande
Nacreous
Jul 21, 2014Maximum connection limit
Maximum connection limit at pool level for pool members is based on which parameters. I can see some of the pool is having 16k while some as 4k. Is it editable at pool member level?
- Kevin_Davies_40
Nacreous
Click on the pool member. See near the bottom the Connection Limit field.
- gsharri
Altostratus
What statistic are you referring to? If you mean the "Maximum connections" stat for a pool member, that number is not a limit. It is showing you peak, concurrent connections.
