Max Sync Retransmission in Monitors
I can change "Max Sync Retransmission" in the TCP Profile for the Virtual Server traffic.
But, Can I modify the "Max Sync Retransmission" for the traffic generated by the BIG-IP?, for example Monitors.
The normal behavoir when the unit send SYN to server and the server don't respond, is the following:
11:35:45.845495 IP 192.168.0.71.45189 > 192.168.0.73.http: S 2943781555:2943781555(0) win 14600
11:35:48.844895 IP 192.168.0.71.45189 > 192.168.0.73.http: S 2943781555:2943781555(0) win 14600
11:35:54.844939 IP 192.168.0.71.45189 > 192.168.0.73.http: S 2943781555:2943781555(0) win 14600
11:36:06.844885 IP 192.168.0.71.45189 > 192.168.0.73.http: S 2965789555:2965789555(0) win 14600
11:36:30.845087 IP 192.168.0.71.45189 > 192.168.0.73.http: S 2990941555:2990941555(0) win 14600
11:37:18.844925 IP 192.168.0.71.45189 > 192.168.0.73.http: S 3041245555:3041245555(0) win 14600
11:38:55.880704 IP 192.168.0.71.47144 > 192.168.0.73.http: S 2612060070:2612060070(0) win 14600
11:38:58.880009 IP 192.168.0.71.47144 > 192.168.0.73.http: S 2612060070:2612060070(0) win 14600
11:39:04.889167 IP 192.168.0.71.47144 > 192.168.0.73.http: S 2612060070:2612060070(0) win 14600
Between each SYN the time is the double that previous SYN.
This beheaviour is related to Max Sync Retransmission param configurable in tcp profiles but we don't know how to modify this parameter for the bigip monitors. we want unit to retry every 5 sec. Is it possible?
- What_Lies_Bene1
I don't believe you can configure this setting I'm afraid.
