dburnett_103851's avatar
dburnett_103851
Mar 10, 2009
Max No. of Headers
Just wondering what other ASM users have this set to in their HTTP Protocol Compliance settings.
The default value is 20 but I've started to notice requests from what look like mobile 3G devices being blocked because they exceed this number.
Anyone know why F5 set the level at 20 (must have been a reason) and what is a sensible level to set if increasing from the default?
  • hoolio's avatar
    hoolio
    Out of curiosity, what are the header names/values that the WAP clients send? I know some WAP devices have very very long Accept headers, but I haven't seen requests with a large number of headers.
    I would guess the setting is there to protect apps that crash from parsing too many HTTP headers. Maybe someone from F5 would like to comment on this. Else, you could open a case with F5 Support. The only concrete vulnerability I could find on the internets is to an old Secunia alert:
    http://secunia.com/advisories/12666/
    Description:
    Luigi Auriemma has reported a vulnerability in Icecast, which can be exploited by malicious people to compromise a vulnerable system.
    The vulnerability is caused due to a boundary error in the parsing of HTTP headers. This can be exploited to cause a buffer overflow by supplying more than 31 headers in a HTTP request.
    Successful exploitation allows execution of arbitrary code.
    If you're seeing legitimate requests with more than 20 headers you can increase it to a level above the highest number of headers you've seen in a legal request, or you can disable the check. I suppose you could also use an iRule to remove request headers which the app doesn't use.
    Aaron
  • This is an example of one such request (sanitised a little) which seems to have come from a samsung mobile device and has 23 headers:
    GET /home/_site/campaign/isa09/index.html HTTP/1.1
    X-ICAP-Version: 1.0
    Host: www.XXXXXXX.co.uk
    Connection: keep-alive
    Content-Length: 0
    Cookie: TS4b6c63=b793df88d6d751a4f3d76bdc2324649738b61ea5845562c149b819e7; PD_STATEFUL_9bbcce68-1d01-11dd-b04f-c0a84102aa77=%2Feai;
    Cache-Control: no-cache
    Pragma: no-cache
    Accept: application/vnd.wap.xhtml+xml, application/xhtml+xml, text/html, application/vnd.wap.wmlc, image/vnd.wap.wbmp, image/png, image/jpeg, image/gif, image/bmp, text/vnd.wap.wml, text/vnd.wap.wmlscript, application/vnd.oma.dd+xml, text/vnd.sun.j2me.app-descriptor, application/java-archive, application/vnd.wap.multipart.mixed, multipart/mixed, application/vnd.oma.drm.message, application/vnd.oma.drm.content, */*
    Accept-Charset: utf-8;q=1.0,utf-16;q=1.0,iso-8859-1;q=0.6,*;q=0.1
    Accept-Language: en
    Referer: http://www.XXXXXXXX.co.uk/home/_site/channels/savings/tax-free-savings/fixed-rate-cash-isa/index.html
    User-Agent: SAMSUNG-SGH-G600/G600ABHF1 NetFront/3.4 Profile/MIDP-2.0 Configuration/CLDC-1.1
    x-wap-profile: "http://wap.samsungmobile.com/uaprof/SGH-G600.xml"
    X-Nokia-RemoteSocket: 10.46.195.135:13848
    X-Nokia-LocalSocket: 193.35.132.107:8080
    X-Nokia-Gateway-Id: NBG/1.0.91/91
    X-Nokia-BEARER: GPRS
    X-Nokia-CONNECTION_MODE: TCP
    Cookie2: $Version=1
    X-Orange-ID: b2sjeqTnpjxP0JrtSMLmYw==
    X-Forwarded-For: 10.46.195.135, 193.35.132.106
    Via: 1.1, 1.1 bdp-proxy2 (NetCache NetApp/6.0.6P1)
  • Ido_Breger_3805's avatar
    Ido_Breger_3805
    Historic F5 Account
    The reason like Aaron mentioned is simply to prevent an application DOS/failure due to parsing many headers.
    We believe that 20 is a good number for 80% of the apps..
    Now, if we start to see that many customers share the same case, we would increase this default setting...
    Cheers,
    Ido
    • Zeeshan_Ahmad_1's avatar
      Zeeshan_Ahmad_1
      What is the impact we increase for a single applicaton where the legitimate number of headers is about 40
    • Vijay_E's avatar
      Vijay_E
      Icon for Cirrus rankCirrus
      I have changed this number and have not noticed any issues in the past.
