Luke_Drury_7634
Sep 03, 2009Managment interface is running on all interfaces?
Hi all.
I am a bit of F5 newbie and have setup our LB's without any training, (read tight AR$e boss)
As a result I am learning as I go, so please excuse the seemingly dumb following question.
I have a Pair of F5 Big IP LTM's running version 9.4.6.
I just ran a pen-test of our setup and noticed that the F5's present SSH and the Web Management GUI on all physical interfaces, not just the dedicated management one.
Now I have gone to a lot of trouble in locking down the dedicated management interface behind a separate firewall only to find to my horror that is it presented on every interface/ VLAN the LB is presenting.
I have had a look through the GUI and can't work out how to disable it / only present it on the dedicate management interface, like I assumed it would.
Does anyone have any ideas, how I can configure the F5 to do this?
Cheers Red.
- The_Bhattman
Hi Red,
Go into into the section where you defined the self addresses and select each self address, there is a setting called PORT Lockdown(I can't remember the exact language but you will know it when you see it). If it's already set to Allow default then it's allowing protocols and ports on each of the self-address
PROTOCOL ospf
PROTOCOL tcp SERVICE 4353 (iQuery)
PROTOCOL udp SERVICE 4353 (iQuery)
PROTOCOL tcp SERVICE https (port 443)
PROTOCOL tcp SERVICE snmp (port 161)
PROTOCOL udp SERVICE snmp (port 161)
PROTOCOL tcp SERVICE ssh (port 22)
PROTOCOL udp SERVICE domain (port 53 - DNS)
PROTOCOL tcp SERVICE domain (port 53 - DNS)
PROTOCOL udp SERVICE router (port 520 - RIP)
PROTOCOL udp SERVICE 1026 (network failover)
You have other settings like Allow none, Allow all and allow custom. Allow Custom you can simply lock down port 22 and 443 and let the others through.
Each self address must be locked down that way
Hope this helps.
CB - hoolio
Hi Red,
I don't think port lockdown affects the actual 3.1 management port. You would need to put a firewall in between the management port and any untrusted network.
Aaron - Luke_Drury_7634
Hi Aaron
Thanks mate, yeah I have it locked down behind a separate firewall.
Cheers Red
