Maintenance-Irule Issue keeping SSL::disable serverside" intact
Currently we have the below Maintenance-Irule in place which is pointing towards a Pool:maintenance_page which is holding the Maintenance Page-holding server:172.27.60.240:80
But the problem is that this Maintenance-Pool server don't work always, so we are trying to remove this Maintenance-Page server and put some-kind of banner Irule which LB can publish:
when HTTP_REQUEST { if { [active_members [LB::server pool]] <= 0 } {
pool maintenance_page
================= Plan is to edit the above Irule with the below contents keeping :SSL::disable serverside" intact. Kindly suggest:
when HTTP_REQUEST { Check active members of pool, if 0 respond with Apology Page. if { [active_members test-rpm] <=0 } { HTTP::respond 200 content {
The JDA site you are attempting to access is currently unavailable due to system maintenance. Please try the site again in a few minutes. We apologize for any inconvenience this may create. If you need to reach us, please call 1-469-357-6900 or email [email protected]. Sincerely, JDA Cloud Services }
Thanks and Regards Parveez
- Kevin_Stewart
Employee
Perhaps something like this:
when CLIENT_ACCEPTED { set default_pool [LB::server pool] } when HTTP_REQUEST { if { [active_members $default_pool] < 1 } { if { [active_members maint_pool] < 1 } { HTTP::respond 200 content "...html maintenance content..." } else { SSL::disable serverside pool maint_pool } } }
