Anzine321
Cirrus
Nov 06, 2024macOS High Sierra not work and APM Edge Client 7246.2024.129.2022
hi
user used macOS High Sierra not work and APM Edge Client 7246.2024.129.2022
anybody know how to solved this issue becase on this article is not compatible
https://techdocs.f5.com/kb/en-us/products/big-ip_apm/manuals/product/desktop-clientcompatmatrix.html
Hi Anzine321,
I had this issue before, but F5 support solved it with a hotfix. I recommend you open a support case.
