eesun_276598's avatar
Dec 01, 2017
MAC masquerade address
Hi MAC masquerade address could be any one except one used already in the F5? as it is local effective. Thanks
  • Any MAC address that is not on any of the F5 connected networks.
    Best to take a MAC off the F5 and change the first hex pair to 02 to avoid any conflicts.
    e.g. 00:01:d7:93:35:08 to 02:01:d7:93:35:08
  • thanks for your reply. right. I guess making change to 02 of the first hex could make it absolutely unique address. Can you tell why?
    • Andy_McGrath's avatar
      Andy_McGrath
      First half of the MAC is vendor hardware, 02 is reserved so never hard set by a vendor so should make it unique.
  • So we can say that changing any one of the first half part should make the mac unique, right?
      Andy_McGrath
      No as you might conflict with another vendors MAC, though unlikely it is possible.
