Gary_Bristol_19's avatar
Gary_Bristol_19
Oct 21, 2015
Luminis Portal and persistance Cookies and the F5
I don't even know where to begin on this one. I need to look for a cookie that is set on the Servers in a Luminis Portal setup and then based on the Cookie that is set send it to that server on following client connections. the search string can be upto 1000 bytes into the header. Search for the String "fos.web.server=" the next 15 characters are the cookie, lumprodcookie1, or lumprodcookie2 or lumprodcookie3 or lumprodcookie4 or lumprodcookie5, depending on which one it is, the connection will be send to the corresponding server.
service Abe-8008
  ip address 192.168.217.105
  protocol tcp
  port 8008
  keepalive frequency 30
  keepalive uri "/"
  keepalive port 8008
  keepalive type http
  string lumprodcookie2
   content SIS-CPIP
    string range 1 to 1000
    string process-length 15
    vip address 129.15.0.216
    add service Abe-8008
    add service Barney-8008
    add service Maggie-8008
    add service Moe-8008
    add service Snowball-8008
    advanced-balance cookies
    string prefix "fos.web.server="
    port 8008
    protocol tcp
    url "/*"
    balance leastconn
    active
