LTM View Persistence Connections Timers CLI
how can I see remaining time for persistent connection?
For example if I have persistence per source IP address and I want to see how long current connection exists or what is remaining time before connection tear down?
Br, Mate
- gsharri
Altostratus
Use this command to view persistence records:
tmsh show /ltm persistence persist-recordsThe existence of a persistence record does not necessarily mean that there will be an open connection related to that client. The persistence record simply tells LTM which pool member to use if the client makes another request.
Connection timeout is controlled by the virtual servers tcp profile.
- SynACk_128568
Hi
tmsh show /ltm persistence persist-records all-properties
output will show you a row with age it will tell you the how much time has passed in reference to persistence timeout configured on virtual .
- Mate_132781
Thank you for your answer.
Is this meaning that persistence counter starts to count after client session is closed?
For example, we have persistence per source IP and 45 min timeout. Client opens the connection and close browser after 5 minutes.
How long persistence for this clinet to same pool member will be valid?
- hari_126827
Cirrus
Yes normally the client if connects within 45 minutes will connect to same server\pool member.. But it is not the case, then please make sure to create a new tcp profile (with 45 minutes as idle timeout) attached to the virtual server..Default TCP timeout is 5minutes..
Please also see below links:
sol7606: Overview of BIG-IP idle session time-outs
Regards, hari
- nitass
Employee
no. i understand persistence record is created when server is connected.
- Mate_132781
OK, thank you for your answers.
