LTM single port VS and port 0 VS on the same IP address
Is it possible to have a standard VS listening on port 0 (all ports) and at the same time a standard VS with HTTP profile on the same IP address (and only port 80 or 443)? Would the latter one get all connections to the port 80/443 or there is a chance that some connections will be ending up on the former VS?
- ekaleido
Cirrus
It will work as you describe. For reference I am linking a SOL article that describes virtual server precedence.
- Nikolay_Matveev
Brilliant. Thanks.
I struggled to formulate the right search query when tried to look up a suitable SOL myself. I should have thought of "order of precedence"!
- ekaleido_26616
Cirrocumulus
- Nikolay_Matveev
Brilliant. Thanks.
