Javier_Somoza
Sep 18, 2017LTM Policy - Forward to node without using IP
Hi all
Is there any way to configure the forward action in a LTM policy without having to use the IP address? I tried to use FQDN, create a Node object to use its name... but its not accepted.
When forwarding to a single server the only way to not having to use the IP is creating a single node pool and forward to it?
Thanks!
