LTM Policy - Forward to node without using IP
Hi all
Is there any way to configure the forward action in a LTM policy without having to use the IP address? I tried to use FQDN, create a Node object to use its name... but its not accepted.
When forwarding to a single server the only way to not having to use the IP is creating a single node pool and forward to it?
Thanks!
- Leonardo_Souza
Cirrocumulus
Can you please explain better what you are trying to achieve?
The newer versions allow you create a node with IP and name, but I need to understand first what you want to do.
- stan_piron
Cumulonimbus
You can create a pool with FQDN member even if there is only one member!
