karthickyokesh_'s avatar
karthickyokesh_
Jan 25, 2018
LTM_NODE : Could not connect.; Failed to succeed before deadline
Hi
We have a production LTM which is running on version 11.5.3, buildin 2.0.196, Hotfix HF2.
Frequently I can see some of the nodes are down due to below error.
Could someone help me to fix this issue.
Availability Offline (Enabled) /Common/tcp: Could not connect.; Failed to succeed before deadline. @2018/01/25 14:23:06. Health Monitors tcp
  • Hello,
    This is a normal error showing that applied monitor failed. There could be a lot of reasons but you can check if the server is listening on the correct port and your FW rules between the F5 and the server.
    Regards
