SuRaSej_89044
Apr 20, 2009LTM and Link Controller path check question
First of all, i would like to apologize for my english.I have a couple questions about Path and link monitoring.
1. Why should i mark a Transparent to YES for icmp gateway monitor? Because i think it is enough that we use a alias address.
2. If we must select a Transparent to YES,what the different when we use it or not?
Could anyone please answer this topics to me?I always wonder about this.Thank you for your attention.
Best regards
Surasej
- dennypayne
Employee
Hi Surasej,
Transparent means that you are monitoring *through* the device to another address, rather than just monitoring that address itself. In other words, if you want to monitor a firewall or router, it does you no good to ping the inside interface because that doesn't tell you anything about path availability. So you monitor through that device to something else.
Hope that helps,
Denny - SuRaSej_89044
Thank you very much Denny.I have read some manuals,solutions and complying them with your comments.So i think i understood it now but i think i should test it in my lab.Thank you for your help.
Best regards
Surasej
