LTM and internal vlans and external routing
I have a situation where there are two internal vlans in an LTM. The vlan names are Internal and Servers with relevant self IPs. The LTM routes traffic via the external vlan to an upstream router. An IP forward VS has been setup having server vlan as source to any destination. This is to make nodes in the server vlan to talk to outside network for some backend activity. This is working fine when nodes from the server vlan talks to any outside network. The issue we are having is when nodes in Server vlan talk to nodes in Internal vlan and because both internal vlans are directly connected F5 tend to route internally. The requirement is to have the nodes in server vlan to egress via the external upstream gateway.
Is it possible to achieve this by, using the same IP forward VS to do a source-network based forwarding (server vlan network) and set the next hop as external gateway or any other options available?
Any help would be much appreciated.
Thanks & Regards
