francisluo_3039's avatar
francisluo_3039
Jun 24, 2008
LTM 4.5.1 Web UI management interface not accessible
Hi There,
I have a LTM 2000 with 4.5.1 version. Suddently the unit's management Web UI can not be open. The port 443 is not accessiable. But all virtual servers are working fine.
Restart httpd and tomcat did not help.
Any suggestions are welcome.
Thanks,
Francis
  • Just find out theat inetd is not running. It can not be restarted with bigstart startup command. Is the only option to reboot it?
    bigstart: status inetd
    status inetd: is not running
    Thanks,
    Francis
  • hoolio's avatar
    hoolio
    Hello,
    inetd doesn't run by default on 4.x. What do you see when trying to connect to the admin web interface? Can you run a tcpdump on the BIG-IP command line while trying to connect in a browser? Are there any errors in /var/log/httpd or /var/log/secure? Are there host based restrictions in /etc/hosts.allow?
    Aaron
