Logon using UPN without server side Kerberos on F5
While implementing Exchange Autodiscover, Ews, Outlook Anywhere, and OWA through the exchange iApp (logon using an AD AAA object), I noticed that I cannot authenticate using the UPN of the user accounts. Using the SamAccountName attribute authentication works fine. In my environment the UPN suffix is different from the FQDN. So when logging in an account named tpriv with the UPN: [email protected], the APM log shows the error: AD module: authentication with 'tpriv' failed: Client '[email protected]' not found in Kerberos database, principal name: [email protected]
F5 support indicated that it is possible to disable server side kerberos through an irule. What would it be? Or perhaps I can get this authentication traffic to skip the APM, and go through LTM only, so that authentication is handled by the Domain Controllers/Exchange servers.
Thanks for any help!
if you used the iApp you can run it without APM and then do the authentication right on the exchange servers.
of course APM does give you some extra security. what you can do is perform an AD or LDAP lookup based on the SamAccountName and then get the UPN and use that as authentication username value.
here is something similar discussed: https://devcentral.f5.com/questions/using-apm-to-authenticate-to-windows-ad-with-a-upn-that-is-different-then-our-domain-name
